John Robertson
What is the cause of audio clipping in a transistorised amp? Is it a
underpowered transformer not providing enough voltage/current to the
transistors, too much voltage/current to the transistors, or the transistors
themselves need higher voltage/has too much voltage (not transformer fault)? Or
something totally different?
I keep reading about amps getting into "overdrive" which causes the clipping,
but don't understand what this is. I have also read that valve amps have a more
soft clipping, while transistorised amps have a more hard clipping. Is this
correct?
If it is something as simple as a transistor getting too much voltage/current,
couldn't one then just lower the voltage/current to the transistor to stop or
at least lower the amount of clipping/distortion?
correct?
