Mark
I want to use a precision 5 volt reference as Vref for the adc on an
Atmega16. My problem is that the Vcc uses a common 78L05 regulator, whose
output can range from 4.75 to 5.25 volts. Can I tie the AVCC to the 5 volt
reference instead of Vcc? Will I get accurate adc readings if Vcc is say 4.8
volts while AVCC is 5.00 volts? Thanks for any advice.
Mark
Mark
