Nemo
I have a purely analog circuit operating at up to 1MHz, though it is not
inconceivable that at some point in the future it will be modified to
work at 10MHz. [Just future proofing here - I already saw one project
where Marketing asked if they could stick a 0 on the end of the spec.
This is better than some places I've worked where they didn't ask!]
Signal levels are in the mV region at the start of the circuit, rising
to a couple of volts at the output.
I intend using stripline to impedance-match the output to the cable it
drives. My question is, for the earlier stages, is it better to try and
use series resistors and impedance-match the tracks between stages, or
simply to use big fat tracks for minimal inductance? The IC's will be
about an inch apart (much less if I can manage it). The IC's involved
have significantly higher GBW's than the signal.
Thank you,
Thank you,
