Jeff
Hello,
I've been simulating a circuit of the 'classic' astable multivibrator
and analysing the results. This is the old-fashioned two-transistor
design where each device (both NPNs) alternately turns off/on the
other. I'm sure you know the type of thing. Anyway, the collector
voltage of Q2 goes negative to almost the extent of the supply rail! Is
this a Spice anomaly or would a real world circuit do the same? I don't
see how it's possible for a circuit to generate sub-ground voltage
levels. Isn't that theoretically impossible? The clock rate is 400Hz
and Vcc is 5V.
-Jeff.
and Vcc is 5V.
-Jeff.
