Hello All, I'm trying to expand my old electric drum kit with a new (better) kick drum, however, they are incompatible and I was hoping to make a project box that gets the new pedal triggering the drum module correctly. I'll try and describe the problem as clearly as possible, I am only semi-elecro-literate but have put together simple circuits before.
The new kick drum trigger is a piezoelectric pickup, so I guess the harder you hit the kick-drum the higher the voltage generated.
The old drum pedal trigger is a mechanically operated variable resistance switch. When the pedal is pushed gently the switch closes further down a resistance track closing the switch with more electrical resistance which the module interprets as a quieter volume. As you increase the force on the pedal, the switch gets closed further up the resistance tracks causing less resistance which tells the module to play a louder kick-drum sound. (There is a current running through this switch from the drum module)
Can anyone think of a simple circuit that I could plug in between the new kick-drum and the old drum module, please? I would imagine it would need some way of adjusting sensitivity too?
Thank you in advance
