ASRock 939A790GMH
Skybuck Flying
Ok,
At one webstore I have little choice for a replacement, the only socket 939
motherboard they have is this relatively new one:
ASRock 939A790GMH (Retail, RAID, Gb-LAN, VGA, Sound, µATX)
(AMD 790GX chipset)
Some issue's:
1. It's micro atx but my case can mount that I think.
2. It has very little space for PCI express, if I were to add my graphics
card to it then it would pretty much be full, the remaining pci express
would be unavailable because otherwise it would block the airflow.
3. It only has 1 network port, thus this would require an additional network
card which doesn't seem possible unless perhaps the little port is used.
Quite strange that it has a little port... there is very little hardware for
it as far as I know... pretty insane... I suspect it might be used for
debugging purposes for hardware or so ?!
4. I can forget about using the creative labs soundblaster which on one hand
would be a real shame, because it has nice software too and just got the
drivers working... and less frames in games... but on the other hand perhaps
I will then not kill the motherboard anymore...
I probably figured out how to connect 7.1 to motherboard, apperently not all
holes need to be used, one might be optical, so only 3 outs are probably
present which is exactly what it would need, but never tried this.. perhaps
more is necessary after all so I am not sure if I would be able to connect
the receiver. The motherboard as protected outputs... but perhaps it's still
possible to kill it one connecting receiver when power is on...
5. There seemed to be some troubles with smart information reading from sata
drives, some also say the sata drivers are slow/bad... might be an issue.
Also it seems to have aluminium solid capacitators ?!? not sure what that is
It also has an integrated graphics cards which is kinda interesting, but
it's not very powerfull, I doubt it can do opencl probably not.
Perhaps I should look a bit further at other stores...
Feel free to comment ;) :)
Bye,
Skybuck.
Skybuck Flying
Skybuck Flying said:
Hmm,
This is very surprising it seems to come with some kind of creative labs
x-fi MB thingy ? software ?
http://www.asrock.com/mb/overview.asp?Model=939A790GMH
http://www.creative.com/oem/pressreleases/asrock_111009/
Could be interesting... then again I already have X-Fi soundblaster but if
it's bad, then maybe this onboard thing is a nice replacement.
Yeah it's a software, and trail too... I guess this could prove that X-Fi
soundblaster is just bullshit and it's all software back-ed up by some audio
processor... pretty lame, and it caused all this trouble... gjez...
Bye,
Skybuck.
Skybuck Flying
The more I look at this board, the more I start to like it... it's passively
cooled... that's pretty cool... but I might also look at newer sockets in
case I decided to replace everything with lower watt's/tdp's components ;)
Bye,
Skybuck.
G
GMAN
Bye,
Skybuck.
No, having the SB card smacked between two SLI'd video cards with less than
millimeters of space between them is what probably killed the board/card.
Skybuck Flying
than
That's not how it was placed in the third build, only 1 gpu and 1 soundcard.
So all this "chat" and "thought" about to little airflow is B.S.
My PC had more airflow then 99.9% of the pc's out there is my bet ! ;)
Other theory could be heat from harddisks and/or memory chips...
I will have to look into that as well... but I suspect that little bit of
heat (though still 60 degrees power connectors from harddisk) will quickly
be blown out of case... but I could be wrong... this heat from harddisk
could perhaps also slowly frie the motherboard.
Perhaps I even have further evidence that there was a lot of heat in the pc
case, too much heat, perhaps also caused by a little bit of turbulence by
the plastic fan holder that came with antec 1200 inside the duct... none the
less still enough airflow. The evidence is the see through window... it
seems to have melted just a little bit... like 1 nanometer or something... I
placed it near my balkony door and placed in a certain angle/light I could
see a "oil-like rainbow".
Perhaps this "oil like rainbow" is from the manufacturing process but it
could also be a "heat related oil-like rainbow".
So the rainbow could have been produced by heat... perhaps little particles
stuck to the window... perhaps oil particles from cars/busses from the
neighbourhood.
The oil pattern seems to follow the flow of the airflow.
Perhaps later I will try to make a nice picture of it to show you guys just
for the fun/interest of it ! ;) =D
None the less... if I am right then another sign of way too much heat in the
case... there shouldn't be an oily pattern like that ! ;) =D
Bye,
Skybuck.
Skybuck Flying
Also there was a huge ammount of dust in the graphics card heatsinks... I
haven't cleaned it in a few years or so... also some oil I put in there
might have made it slightly worse... but the oil probably has little to do
with it...
Though the oil that I put in it could also explain the oily look on the
window... perhaps a few of those oil particles got heated and started
drifting...
Anyway I am tired of the whole dust situation with the antec 1200... last I
heard from you you had that case as well ?! You tired yet of cleaning those
dust filters every month or two ?
And the dust filters don't even help that much...
I am sick of the dust crap... another good reason for to stick with
"passively cooled" heatsinks...
At least they don't collect dust that fast... and will probably continue
working even if there is a little bit of dusting lieing on top of it...
The question remains what happens to a 7900 gtx if it's heatsink is full
with dust ?!? It will continue to function... but what happens to the heat
around it ?!? Will parts of the motherboard around it start to heat up, fry
? damage ?
Also most of the burned looking spots... could also be corrision but I don't
think it's corrision seem to be along the lines of the motherboard.
So either the motherboard it self is processing to much data... like to much
bandwidth is flowing through it causing these tiny little lines to heat
up...
Or the heat from other components is crawling/creeping into these tiny lines
like a radiator and spreading the heat across the motherboard... ultimately
leading to some kind of motherboard death.
So another good reason to get rid of hot components is to prevent "heat
crawl" lol ! ;) =D
Bye,
Skybuck =D
Skybuck Flying
The theory/hypothesis of oil particles drifting and melting onto the window
can probably be dismissed, since I whiped that window with a dust cloth a
couple of times in the past... I can't imagine the temperature to be hot
enough to melt oil particles into the window... I could be wrong though...
but I don't think so...
It's probably the glass-like-plastic itself that got heated up by airflow
and got somewhat heated/melted to form this oil pattern... or it was
production process... but this last seems a little bit unlikely... I'd love
to see a video/picture of a new/unused plastic window to see if it has the
oil pattern or not... and not just any oil pattern but an airflow like
pattern ;)
Bye,
Skybuck.
Skybuck Flying
I am considering this board out of lazyness, however figuring out how to
connect the 7.1 receiver to it is the hard part.
http://www.asrock.com/mb/overview.asp?Model=939A790GMH&cat=Specifications
This sentence is a bit weird:
"- HD Audio Jack: Rear Speaker / Central / Bass / Line in / Front Speaker /
Microphone"
Almost seems like only a few speakers can be connected ?!?
Anybody know for sure if 7 analog RCA/speakers can be connected to it via
receiver with 3 plugs or so ? (Don't need bass).
I'll go check manual, maybe there is some information inside it about but I
doubt it... the asus manual didn't...
Bye,
Skybuck.
Skybuck Flying
Ok, asrock's manual is a bit better, it explains what each audio hole does
and how it can be configured... what's missing is what kind of cables
needed... I am guessing probably 2 metal ring plug cables or something or
maybe 3...
Gonna be extra expensive if I have to buy new cables again... but old cables
will probably fit but won't go in entirely or maybe they will... perhaps
using wrong cables could even lead to damage ?
Bye,
Skybuck.
Skybuck Flying
Hmm.. I spotted an incompatibility with my memory sticks.
First of all I have 4 memory sticks.
The board only has 2 slots available.
Second of all the slots are 240 pins while my sticks are 184 pins.
This is very tiring.
A new interesting development is integrated motherboards with cpu gpu audio
network on it, but no memory sticks.
Perhaps in the future the whole board will be complete including memory
sticks.
Then it's just selecting one integrated motherboard/pc and be done with
it...
Now I have to start a whole new selection process for components and check a
zillion little thingies to spot these kinds of tiny little fucky issue's,
takes huges ammounts of time, like weeks, which sucks.
Alternative is to find another webstore with an old socket 939 motherboard
which does fit my old hardware and try to keep it going for as long as
possible for now...
Bye,
Skybuck.
Skybuck Flying
Lol...
I was watching the manual of an integrated board... I am starting to confuse
things lol.
The ASRock 939A790GMH does have 4 slots... and probably 184 pins... but I am
gonna check to be sure...
Apperently the integrated board is 240 pins and something else ;)
Bye,
Skybuck.
Skybuck Flying
Hmm, so far there is one thing missing on this board... a parallel printer
port... hmm...
Maybe I'll buy a new printer... I still got an old printer from the stone
age ! ;) =D
Bye,
Skybuck.
Skybuck Flying
Well concerning the audio cables.. I'll probably need new audio cables
again... which is really depressing..
Current 3 cables are: 1 plug to 3 rca's.
These were necessary for creative x-fi soundblaster, these were actually
video cables used as audio cables.
Since the soundblaster would now be left out, which I regret but might
ultimately be better but I doubt that too but ok...
these cables will have to be replaced with:
4 cables: 1 plug to 2 rca's.
Such cables can be quite expensive about 10 to 16 bucks per cable... so
that's 4x15 bucks or so.. is another 60 bucks.
Which makes this a bit expensive...
However the audio back plate of the motherboard also has optical out and the
receiver has optical in... so perhaps if such a cable could be used to
support 7.1 then that would be pretty cool... only 1 cable needed, and
perhaps less chance of electrical damage...
Also no need any more to figure out how to connect them... though I did
label the 3 cables with a bit of sticky tape ;) but not the rca 8's so if I
unplugged those from the receiver I would have to re-figure that out
probably... but that's something I would normally not do... and let them
hang in the receiver...
Hmmm another documentation failure... receiver manual contains no
explanation of optical in/out/cables...
This seems to be a prime candidate for a nice question on an audio
newsgroup... to see if anybody has experience connecting optical
pc<->receiver.
Last time I read something about that it was limitations in x-fi
soundblaster which would loose certain features...
I wonder if on-board audio has such limitations as well or perhaps not ?! ;)
Bye,
Skybuck.
Skybuck Flying
I just spotted a potential issue with this board.
The cpu fan connector seems to be 4 pins, while the amd x2 3800+ stock
cooler fan comes with 3 pins connector.
Perhaps it can be connected, but I have seen stupid issue's like this
before.
The manual of asrock also seems to have things swapped, the manual actually
believes cpu_fan1 is 3 pin, while the screenshots show 4 pins.
There are 4 pin after mark cpu coolers available which I am interested in.
Perhaps this board can use both, the manual says so... but it's been wrong
before apperently... hmmm...
Bye,
Skybuck.
Skybuck Flying
Ok,
It's not an issue for me at least, the connectors will probably fit, I was a
bit confused about the motherboard manual... but now I understand what it
means... so it's ok.
The 4 pin connector is kinda nice it offers speed control.
I think I will buy the most advanced cpu heatsink/fan I can find which blows
maximum ammount of air...
And then hopefully the motherboard can throttle it a bit... so it doesn't
need to spin at max that be cool.
I also have earplugs nowadays... so I can have some noise ! ;)
It shouldn't be excessive though ! ;)
Bye,
Skybuck.
