Peter
I have installed a number of SSDs in desktops (24/7 operation) and all
failed within a year or so.
Example:
http://www.crucial.com/store/partspecs.aspx?IMODULE=CT256M4SSD2
They get replaced under warranty but the result is still rubbish, not
to mention hassle, loss of data (we have tape backups but it's still a
hassle). It seems that specific files (specific locations in the
FLASH) become unreadable. The usual manifestation is that the disk
becomes unbootable (sometimes NTLDR is not found; those are fixed
using the Repair function on the install CD).
Just now I have fixed one PC which used to simply reboot (no BSOD) and
then report "no OS found" but if one power cycled it, it would start
up OK. Then it would run for maybe an hour before doing the same. That
was a duff Crucial 256GB SSD too - £400 original cost. I put a 500GB
WD hard drive in there (using the same motherboard SATA controller)
and it is fine.
Years ago, on a low power PC project which shut down its hard drives,
I did some research on what types of disk access windows does all the
time and how they can be stopped. It turns out that it accesses the
registry c. once per second, and it is a write, not just a read. On
top of that are loads of other accesses, but these tend to die out
after a long period of inactivity, and in an embedded app you can
strip out various processes anyway. But the registry write cannot be
disabled (in fact on a desktop O/S most things can't be) and even at
~100k writes per day to the same spot, this is going to wear out a
specific FLASH area pretty quick. They are good for OTOO 10M-100M
writes.
But don't these SSDs have a microcontroller which is continually
evening out the wear, by remapping the sectors?
Their performance is great, especially if you get one with a 6gbit/sec
SATA interface and a quality fast controller (Adaptec) to match that.
I've seen 10x speedups in some functions.
I gather that under win7 things are done differently (it supports the
TRIM function, but that's unrelated to wear spreading AIUI) but for
app compatibility reasons, etc, we use XP.
OTOH I have installed 3 SSDs, much smaller at 32GB, in XP laptops, and
all have been 100% fine. Those were made by Samsung. But those don't
get run 24/7.
I have a couple of 256GB SSDs which have been replaced under warranty
but which are basically unusable for windoze (XP). Can they be used
under say Unix (we have a couple of FreeBSD email servers)? Or is
there some winXP driver which can continually remap the logical
sectors?
Example:
and it is fine.
writes.
get run 24/7.
sectors?
