I
Ignoramus28489
Two questions:
Question 1.
I suspect that the answer is no, but want to doublecheck.
My tig inverter's snubber specifications call for a 0.16 Ohm snubber
resistor.
I have a large, about 4" long, wirewound (better called metal tape
wound), 0.2 ohm resistor. It is rated for 100 watts and is about 1"
thick and has maybe 20 turns of metal ribbon perhaps 3/16" wide.
Can I use this monster as a snubber resistor, or would it not be
suitable due to its inductance?
If not, what resistor would you suggest.
Question 2.
Can I simply skip the resistor in the RC snubber, in my application.
Especially since my bridge is shorting and there are no times when it
is open.
I experimented with a nice big cornell dubilier capacitor and found
that it reduces ripple to next to nothing, without a resistor. Adding
a 0.05 ohm resistor made things much worse for some reason.
I understand that resistor is there to suppress oscillations, but,
ultimately, why should I care too much about those oscillations.
i
Question 1.
resistor.
Question 2.
is open.
i
