Hey everyone. I haven't done anything electronics related in over 11 years and what I did do was on breadboards for highschool.
I'm trying to make my sister a mellohead (
) as a present but I'm stuck at the electronics.
This "tutorial" is kind of terrible and I basically used it as a parts list:
LED Strip x2: https://www.amazon.com/Mokungit-Ind...890260&sr=8-118&keywords=led+lights+ip20&th=1
Arduino Uno: https://www.amazon.com/Arduino-Uno-...e=UTF8&qid=1491890393&sr=8-3&keywords=arduino
Power Source: https://www.amazon.com/Anker-PowerC...&qid=1491890560&sr=8-2&keywords=battery+anker
So, the setup has a rocker switch but I know how to wire that in after research. The parts list also called for 1k resistors, but I don't know if they are needed or where they would even go. I did some resea rch and it seems the only one I need is between the switch and the arduino uno.
My main question is, how to I wire in the led's to arduino uno? I've seen quite a bit of conflicting information on the internet so I figured if I asked for a specific configuration, I'd have better luck wiring this helmet.
Thanks for the help in advance, if you need any more info, let me know.
