Hello!
So i've been fidling around with my arduino, a rgb led and an accelerometer.
I've tried out some tap detection, and got it to work, and decided i wanted to do something with it.
So i hooked up an RGB led, and am trying to make it change color for each tap.
The tap detection works, but the led colors are all wrong :S
Here is my code:
What happens is that when i write the program, the Led starts out lighting up BOTH green and blue. When i TAP it changes to RED. When i tap again, it is still RED. When i tap again, it goes to BOTH green and blue.
I can't see why :S
Halp?
Here is my code:
Code:
// these constants describe the pins. They won't change:
const int xpin = A2; // x-axis of the accelerometer
const int ypin = A3; // y-axis
const int zpin = A4; // z-axis (only on 3-axis models)
const int red = 9;
const int green = 10;
const int blue = 11;
//int sampleDelay = 50; //number of milliseconds between readings
void setup()
// initialize the serial communications:
Serial.begin(9600);
//Make sure the analog-to-digital converter takes its reference voltage from
// the AREF pin
analogReference(EXTERNAL);
pinMode(xpin, INPUT);
pinMode(ypin, INPUT);
pinMode(zpin, INPUT);
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
digitalWrite(red, HIGH);
digitalWrite(green, HIGH);
digitalWrite(blue, HIGH);
int x = 0;
int y = 0;
int z = 0;
int prex = 0;
int prey = 0;
int prez = 0;
int redVal = 0;
int greenVal = 0;
int blueVal = 0;
boolean redb = false;
boolean greenb = false;
boolean blueb = false;
void loop()
//Defining previous readings
prex = x;
prey = y;
prez = z;
Serial.print( analogRead(xpin));
Serial.print("\t");
//add a small delay between pin readings. I read that you should
//do this but haven't tested the importance
delay(1);
Serial.print( analogRead(ypin));
Serial.print("\t");
delay(1);
Serial.print( analogRead(zpin));
Serial.print("\n"); // delay before next reading:
//delay(sampleDelay);
delay(1);
//Reading current x,y,z
x = analogRead(xpin);
delay(1);
y = analogRead(ypin);
delay(1);
z = analogRead(zpin);
//Detect if the difference between last reading and current
//reading is too far apart, tap occured
//Tap detection is quite sensive, too sensitive?
if(
(x > (prex + 10) || x < (prex - 10)) ||
(y > (prey + 10) || y < (prey - 10)) ||
(z > (prez + 10) || z < (prez - 10))
Serial.print("TAP!!");
Serial.println();
//Switch color
if(redb){
redVal = 255;
greenVal = 0;
blueVal = 0;
redb = false;
greenb = true;
}else if(greenb){
redVal = 0;
greenVal = 255;
blueVal = 0;
greenb = false;
blueb = true;
}else if(blueb){
redVal = 0;
greenVal = 0;
blueVal = 255;
blueb = false;
redb = true;
}else{
redVal = 255;
greenVal = 0;
blueVal = 0;
greenb = true;
delay(1);
analogWrite(red, redVal);
analogWrite(green, greenVal);
analogWrite(blue, blueVal);
//END of color switch
delay(150);//Delay to prevent false tap detection
delay(1);
delay(1);
//End of tap detection
delay(10);
I can't see why :S
Halp?
