Problem: I recently acquired a Thunder Blade sit down arcade game that utilizes two 100v strobe lights on the back of the seat to randomly flash through green and red lenses. The original strobes include a circuit that creates the random flashes with just regular 110v input. I order the new version of the strobe since my were not working. Unfortunately, the new version doesn't have the flash circuit built it. It charges when powered and the flashes with the power is removed.
Need: I would like to have circuit that I could build and place into the machine that will flash the two stobes randomly and at different intervals. There is room in seat back to put a small circuit board. I really don't need anything fancy and the simplier the better as I'm just a novice at circuit building.
Functional Specification: Input is 110v. Output is randomly timed 1 second pulse of 110v to the each of the strobe devices independently of the other.
Parameters: While I do have access to 5v DC with in the cabinet I would prefer not to draw that power from the CPU. It should be robust enough for the flashes to occur for periods of 4 to 5 hours at a time. Flashes should not be fast as these lights are trying to emulate the strobes found on aircraft.
I am not at all adverse to using a flash circuit taken from some type of sign or decorative lighting.. if I could find one. There is a prebuilt circuit available on the net for those building RR lights or traffic lights in their man cave.. but these flashers are too consistant for the look I want and these will be my last resort.
Thanks in advance for any help you can provide!
