Pawel said:
Does anybody know what is the arc shape in a typical 400W metal halide lamp,
commonly used now for big area lighting (streets, etc.)? I'm going to use
such lamp in a diy LCD projector, and I wonder if I can mount it diagonally
to the LCD array (to make the whole box smaller, as this lamp is long). But
I don't want to obtain a non-symmetric differences in screen brightness, if
the arc isn't actually circular, or very close to circular.
Thanks in advance for information
It depends on many factors. Most important factor, is plasma pressure
and temperature, but other factors come to play, such as tube shape and
discharge constituents.
Usually halides have specific burning positions, but can tolerate some
deviation from the indicated standard, with some reduction of their
output and change of their color rendering.
Most tend to have fixed burning positions as convection currents push
the arc towards the upper part of the tube depending on position, with
higher iodide concentrations towards the bottom of the tube.
For example the American MetalArc halides tend to condense Scandium and
Sodium iodides on the bottom, giving the bottom part of the arc a
slightly warmer color, while the upper part tends to be mercury dominated.
European halides have a different tube design which allows for greater
tolerances in burning position, although Sodium, Thallium and Indium
condensates can be found on their tube bottoms as well, causing the arc
to bend (for horizontal burning ones) and with the lower part looking
sodium-yellow while the upper part looks more Mercury like.
If you are concerned about uniform arc distribution, check the
Super-MetalArc by Sylvania, which have rigidly fixed burning positions
achieved with Position-Oriented Mogul bases and specially designed
discharge tubes to accommodate convection.
For all the rest, you will get a non-uniform arc color, even if you burn
them in their specified positions, because of the condensates.
The only 400W halides I've seen with almost perfectly uniform arc shape,
are the HQI-T/D by OSRAM. All the rest bend or distort their arc somewhat.
Note that the distortion is of course much less on vertical burning
positions, but it still happens: The arc is warmer on the bottom of the
tube and cooler on top, and if memory doesn't fail me, it's also a
little thinner on the bottom.
