Installed a shower for customer and it failed first time it was used.
There was no power into control board.
Its been replaced and ive got the dead unit.
Ive found two wire wound resistors on the live and neutral wires feeding the control board(see attached pic)
On first inspection only one of these seemed to have failed (O/L) on meter, but i was getting intermittent readings from the second, and with closer looks i noticed the wire had seperated from the lead of the resistor but with movement was making contact and giving false results.
The shower was only installed and tested, which worked fine, then the next day it wouldnt turn on apparantly!! At all?
These arnt cheap , close to 500 pound.
The on off interface is a touch sensitive area on the lower face of the shower.
The only thing i can think that could of been fitter error was connecting the molex plug with power to the unit, instead of connecting then turning power on???
Anyway ive took various photos, it would be great if anyone had any info.
NOTE- The resistors were positioned inline on the Live and Neutral wires, shown in pic.3
