I have this project in my mind where the power/voltage supply is 1.2 V which is turned into
- 70 mV using resistors in the "M' ohm range.
The problem i am having now is how to add it to the IC and combine it with the wave pattern. I know that a NAND will work with a 555 but wanted to make sure if it was correct. Also i wanted to know if a Vresistor would change the volume and a Vcap would change the current flow?
help me out here please
