L
Les Garwood, D.O.
I used to be an electronics repair technician in a former life, and continue
to do repairs for friends and families.
I have an otherwise pristine-looking Applevision 1710 monitor that is as
dead as a cement block. I want to resurrect it b/c my son needs it for his
home/school computer and because I hate to discard potentially salvageable
gear.
So far: Fuse OK, AC traceable on main board, power switch completely OK
(Power LED does not light, incidentally). There is not a millivolt of D.C.
anywhere on the chassis that ought to have some. I have tested it both
attached and unattached to a PowerPC 8500 Mac which is known good, via
another monitor. I can't tell if the CRT filament is burning. And, of
course, Apple being what they are, there is no schematic available outside
of the CIA headquarters.
I've read some interesting snips from anatekcorp.com site that speak about a
Sencore adaptor that is supposed to allow the unit to power-up (providing
it's capable of it otherwise), and about a Triac optoisolator, MOC2A60. The
latter widget has to be turned on in order to power up. Apparently, the
whole thing is a complex loop consisting of a microprocessor, Triac thingy,
and a sensing circuit. An article suggests jumping the settings, and refers
to "Apple's Service Source Companion CD".
So part of my problem involves what to do about the above info, and what
else can I do? I don't have a companion CD or a Sencore adaptor.
Any suggestions would be appreciated.
TIA
Les Garwood
gear.
TIA
Les Garwood
