I see that it works on 2.414, 2.432, 2.450, and 2.468ghz. So you'll need a receiver that will tune to those freqs. If you have a camera that needs power, you need the Red to go to the positive on the camera, Black to the camera ground, and Yellow to the video on the camera. If your camera has audio, then White would be connected to audio. From there, connect red to the positive side of a 1S battery (3.7v) and black to the negative side, or, red to the center pin on the Batt/Bind plug of your RX and black to the side opposite the signal side. If your camera has it's own power, then all you will need is the Yellow video wire, the White audio wire, and the Black ground wire going to the camera and the Red positive wire and Black ground going to the battery. Hope this helps and Happy flying!
