anybody have any 2sd1569a or a good source?
Ron's Television Services
Not sure where you are? but grandata in uk is a good source, they stock most
of the japanese trannys/
Ron
www.ronstv.co.uk
Doug
Thought I could find it in Onkyo's info, but no luck. Have you tried
contacting them?
Doug
Ross Herbert
While the "non A" version would work it would be unlikely to reproduce
the original design spec for the amp. The A suffix usually denotes a
device specified for audio or low noise applications.
That last statement is not always correct, it sometimes denotes a
higher Vceo or some other data.
Not to worry, down to more practical info.
The short form data I have indicates that the 2sd1569 has Vceo = 60V
and a high beta of around 800 and low Vce(sat) though I don't know
what the specific numbers are. The high beta suggests it would have to
be a darlington device. Nevertheless, if you can confirm that a device
with Vceo = 60V will suit your amp then might I suggest the Fairchild
KSD880 http://www.fairchildsemi.com/ds/KS/KSD880.pdf and its
complement KSB834 as alternative devices. You might even be able to
get some free samples from Fairchild.
