Any problems with using X5R/X7R caps as buck converter output capacitors?
Joel Koltner
Before I start dropping some decent fraction of a dollar per capacitor (sorry,
Joerg, the PCB layout guy claims he doesn't have room for electrolytics), I
was wondering if anyone here has had any problems (or successes) using regular
ceramic chip caps with X5R or X7R dielectrics as their main output capacitors
in a buck converter? I need ESR under 250milliohms, which -- while ceramic
caps don't normally spec this -- seems much higher than any guesstimate at ESR
I can make by looking at impedance graphs from the likes of AVX (my
guesstimates range from about 10-100milliohms depending on the particular cap
I look at). I'm looking for some tens of uF here... probably a 22uF cap would
work well.
Thanks,
---Joel
Spehro Pefhany
work well.
Thanks,
---Joel
They work well, IME, if you can get the capacitance and voltage rating
you need without breaking the bank. I've used them for a a converter
supplying a couple of watts.
Best regards,
Spehro Pefhany
Joerg
work well.
I do this all the time. For example as output caps and as SEPIC caps.
However, you have to make sure that they can stand the ripple current.
Ask the manufacturer for soemthing in writing if not stated in the data
sheet. For larger switchers it is usually best to place several in
parallel. I rarely go above 10uF ceramic per cap.
I used to have one here where I ran a test and (knowingly) exposed it to
insane currents. It could have hung on another 15 seconds but didn't.
After the bang I took the broom and found it on the shovel: It's body
had turned into green bubbly glass.
John Devereux
work well.
One thing to watch out for is the the ESR being too *low*. Some SMPS
chips are unstable without enough ESR on the output!
The chip ceramics I have tried appeared to have very low ESR - in the
region of 10mOhm or less.
But yes, I have used them successfully and much prefer them to
electrolytics now, where it is possible to use them. (I test stability
by connecting a 50 ohm output function generator to the input
/ output, and sweeping DC - few hundred kHz. This seems to highlight
any problems). Also check switch-on transient behaviour and current
limit recovery.
Joerg
Thou shalt not use those. And no LDOs ;-)
But they do have a current limit.
limit recovery.
That is an interesting trick. I've done it to the input but not to the
output. Thanks!
Terry Given
output. Thanks!
very nice trick!
X5R/X7R caps can also sing - I have seen (and heard) this dynamically
varying loads. I built 50,000 50W bucks with X7R output caps - again, 10uF.
bigger caps tend to be more prone to mechanical damage & resonance
(Marcon wrote a nice paper on this). And (esp. HV caps) are VERY
susceptible to heat damage - soldering irons cause microcracks, which
propagate into the cap & boom. green glassy goo all right!
Joerg, when not spec'd what sort of numbers do you use for ripple current?
Cheers
Terry
Joerg
Terry said:
very nice trick!
I like to keep them well under 100mW (I^2 times ESR) and I never use
tantalums in designs except maybe for the odd filter or integrator
application. This paper explains it in more detail:
http://avx.com/docs/techinfo/mlc-tant.pdf
If a manufacturer isn't forthcoming with ESR/current data I move on and
exclude them from the ECO. Mainstream companies such as AVX are usually
pretty good with respect to support.
Joel Koltner
Thanks to everyone for the advice; I've ordered some 10uF and 22uF 0805 and
1206 caps to test with.
I have a demo board that I've been evaluating, and it has this rather odd
behavior wherein the switch duty cycle is not always constant at a given input
voltage. (Input is ~3-4.2V, output is 1.2V @ no more than a a couple hundred
mA, buck topology, current mode regulator, so switch duty cycle always <50% so
this shouldn't be subharmonic oscillation due to inadequate slope
compensation.) As you raise the voltage from 3V, the switch duty cycle is
nice and constant, but at some point it starts jittering around first a
little, then more and more as you continue to raise the voltage, and then it
gets damped out again and at high enough input voltages again the duty cycle
is constant.
Assuming the layout is decent, are there any other likely culprits here other
than loop compensation?
This is not the first time I've seen this sort of behavior in a switcher.
I've seen it in some of my own designs and -- some years ago -- ignored the
problem because I was always being fed with a regulated 24V and din't have the
time or skills then to worry about what happened at, e.g., 20V or 28V...
Even though the output remains in regulation, significantly jittering duty
cycles at certain input voltages is not anything I'd want to put in Real
Product...
---Joel
Joerg
is constant.
Product...
It's usually a loop stability or layout issue. Can you post a schematic?
Some chips are a bit fussy about their supply voltage which usually is
derived from the input. So if the input is noisy they can act up.
Sometimes it helps to supply them via a small resistor and 1uF to GND
right at the supply pin. Unless, of course, it's one of those fully
integrated deals where you have no choice.
Terry Given
current sense inputs are buggers for doing this; low Vsense controllers
just make things worse - I often tack a schottky across Rsense while I
get things to go. and the simple act of attaching scope probes can cause
problems too. I have a jar of HCPL0302 g/d optos, with wicked dV/dt
ratings. I often use these to monitor gate drive waveforms, keeping my
scope the hell away from things. Hell, on one product I added the opto
and associated bits to the PCB (there was a lot of room)
Cheers
Terry
Joerg
Oh yes, Isense. There should normally be a cap of a 1000pF or so,
preferably right at the Isense pin of the chip. Even if the datasheet
says that the first hundred nsec or so get blanked out really mean
spikes can still pollute the innards of the chip.
Terry Given
yep. all fun & games. And, to add insult to injury, the problem is often
WORSE at low power levels - high sense resistor voltages, and often high
transformer capacitance (many turns), so Rs*CdV/dt can be ludicrously large.
Cheers
Terry
Joerg
large.
Now I am not sure what you mean, maybe we are talking about different
things. I meant Isense to cut the cycle when the inductor current
reaches a certain level. At really low power levels a proper switcher is
to behave like a Harley-Davidson at idle. One of the guys on the German
NG has the problem that his LM3478 isn't doing that but pumping instead,
causing half a volt of triangles on the output voltage. Up to 40msec
cycles, bizarre. Kind of hard to help him with that when his workbench
is 6000 miles away.
John Larkin
A number of linear regs and some of the Simple Switchers are unstable
with very low esr. Some datasheets say so, and some you have to inferr
from app notes. We use one Micrel buck switcher that's very pickey
about esr, and the only way to find out is by researching the output
cap that's used on the eval board.
Of course, all our boards have scads of 0.33 uF ceramic bypass caps
scattered around. They may not be on the power supply sheet of the
schematic, but they're sure present electrically. Seems like an
electrolytic with some modest esr (even a polymer) damps the ceramics
enough to keep most things happy: pole, zero, pole.
Seems like roughly half the average board is power supplies these
days.
limit recovery.
We bang the output with a load step square wave, and observe transient
recovery. That gives about the same info. If it rings much, it's not
stable.
John
Terry Given
is 6000 miles away.
Hi Joerg,
almost all of my SMPS are Peak Current-Mode Controlled - that being
said, the ones I am doing now are voltage-mode controlled, but with peak
current limits.
we are talking about the same thing, but I shall elucidate.
at FET turn-on, the gate current flows the current sense resistor Rs,
causing a spike. for low-power converters that switch quickly, this
spike can be large - possibly even troublesome. I often re-route the
gatedrive current away from Rs to avoid this.
and also when the FET turns on, it has to charge the xfmr/snubber/etc
capacitance. this Cx*dV/dt current also flows thru Rs, again causing
problems. not many cute tricks to get rid of this - but in DCM can turn
on nice and slow (ware start-up though, it wont be DCM). of course the
FET Cds doesnt cause trouble, other than heating up the FET.
making a very efficient low power PCMC supply that runs from high
voltage can thus be a real PITA - low power = large Rs; high efficiency
generally means fast FET switching hence high CdV/dt current into Rs :(
Cheers
Terry
John Popelish
Terry Given wrote:
(snip)
Have you tried adding a low value resistor in the positive
supply line of the gate driver and capacitively coupling
that to the fet source? This can form a high frequency
short for the gate capacitance charging current.
It won't help with the transformer capacitive current
passing through the drain, though.
Terry Given
John said:
Terry Given wrote:
(snip)
Have you tried adding a low value resistor in the positive supply line
of the gate driver and capacitively coupling that to the fet source?
This can form a high frequency short for the gate capacitance charging
current.
It won't help with the transformer capacitive current passing through
the drain, though.
Hi John,
yep I do that all the time - whenever I have to add a turn-on buffer.
turn-off is easy - I use a PNP, E to gate, C to Source, B to SMPS chip,
with Rg_on across the b_e junction (not that turn-off gate spikes really
causes many problems).
ISTR SGS patented the current redirection scheme we are talking about,
in the mid 90's. But I'm pretty sure I have a schematic in an apps note
that well predates their patent, so I just do it anyway.
and yeah, the xfmr capacitance is a right bugger. which is why one must
pay attention to the design of the xfmr.....
Cheers
Terry
John Devereux
Especially bad are the cheap "hysteretic" converters - ironic since
one of their selling points is "no control loop compensation
required".
Is that what happens? It does seem silly to carefully research a SMPS
"output capacitor" with defined minimum ESR - only to then connect it
to a circuit with a dozen paralleled super-low impedance chip
ceramics!
days.
stable.
I do that too - a swept sine wave to get a plot of effective "output
impedance" vs frequency, then a fairly low frequency square wave to
look at transient recovery in the time domain.
F
Fred Bartoli
ceramics!
Nope. That does make perfect sense because it allows you to taylor your
ESR vs frequency curve and have some where it matters for stability and
'none' where it matters for low HF ripple and low loss.
For a perfect (no esr) ceramics with a // electrolytic the overall Esr is:
Esr (C2/C1)^2 / [(1+C2/C1)^2 + (tau w)^2]
with Esr and C2 being for the electrolytic, C1 for the ceramic and tau =
Esr C2.
So the equivalent ESR decrease from Esr (C2/(C1+C2))^2 at low frequency,
with a 12dB/oct rate above a corner frequency given by Esr and C1//C2
That's a simple to use and very useful trick and SMPSs have a switching
frequency to loop unity gain frequency ratio high enough to benefit from
this.
They are equivalent, except that the transient step test easily allows
some power and might shed some light on some non linear behavior.
John Devereux
ceramics!
your ESR vs frequency curve and have some where it matters for
stability and 'none' where it matters for low HF ripple and low loss.
= Esr C2.
frequency, with a 12dB/oct rate above a corner frequency given by Esr
and C1//C2
switching frequency to loop unity gain frequency ratio high enough to
benefit from this.
Cool, thanks.
(I know from experience that it *does* work, but had not seen it laid
out like that before).
