I am sure many of you are familiar with the newer higher-power SMT
LED's that are out. They generally require larger copper pads on the
PCB to dissipate heat.
I am working on an application where I need a lot of brightness, and
very small size. I also need to have my design be dual color (for
example red and green). My solution was to put the LEDs in strings of
three, side by side but oppositely biased to one another. So that if V
+ is on the left and GND on the right, its red, if V+ is on the right
and GND on the left, its green. Since red and green would never be on
together, this allows me to use the same copper for power dissipation
on both strings.
I was originally using an H-bridge to swap the polarity. But the
design has turned into 6 strings of 3 for red and 6 stings of 3 for
green. Six h-bridges... I am trying to keep the board as small as
possible and I am running out of room doing this with discrete
components.
Of course they make motor drivers that are H-bridges built in, but
they are expensive and overkill for what I need. If I had my wish
come true, it would be for a small chip with 5 or so pins... power and
ground in, a control line, and to outputs. If control is low, output
1 is V+ and output 2 is ground, and if control is high, output 1 is
ground and output 2 is V+. Does such a beast exist?
If not, is there any other suggestions on how to tackle this? I could
do away with the h-bridge idea and just parallel the strings of LEDs,
mass the cathodes (since that's where heat dissipation is needed) and
seperate the anodes and control via transistors switched from the
microcontroller, but I am not sure if that is the best way.
As a non-professional designer, does anyone have alternate suggestions
or something I am missing or perhaps a more elegant solution?
Thank you!
on both strings.
components.
Thank you!
