Any Decent Surface Mount Bread Boards?
L
Leif Erickson
There are 4 different types of decent Surface Mount protoboards here. Ebay
has some in their electronic components areas - chips and pcb's.
A TSSOP-PLCC breadboard- 56 pins, 0.635-.65 mm pitch, with SOIC pads, and
backside has a smaller Rectangular LCC-PLCC and some square LCC-PLCC
footprint fitting 8 to 32 pin LCC-PLCC parts.
Large 4" x 4" PLCC Breadboard- to make your micro-system on 1 board! Up to
52 pin PLCCs, SOIC's and DIP holes, DB-9 connector and more!
2 others - An SOIC(Proto-Chip), and a SOIC/TSSOP/DIP++ type board, to do
other micro and DIP projects and other neat stuff! (Proto-Chip n' DIP)
Not just Adapters, Real Protoboards!
Cut some of Proto-Chip pcb up into smaller pcb's to fit DIP socket headers,
and make a SOIC to DIP adapter, or some other circuit- to fit on a dip
header! Cut in half to make 2 boards, and build a complete circuit on it!
Use the Chip n' DIP board for leaded micros to SMD I/O and ??
Who knows? Take a look! More coming this year! Leave suggestions! Sign in!
Add some tips and info on the corkboard area-links on bottom area of page
below.
