Sir Chuck Navajo1219 . . . . .
WOW ! . . . . . I just absolutely can't get any better referencing , than this, for you .
Obtained from a Riders manual # 6 of circa 1935 vintage and being in pristine condition with these two pages never having been opened onto daylight in 83 yrs.
Of course you'se got's to be initially somewhat Edd-ju-mucated, as you wont find a Bosch radio. You won't even find an American Bosch radio; instead, you have to fully know that they were known as United American Bosch at those early times.
United American Bosch . . .Springfield Mass.
https://www.bertibenis.it/images/American_Bosch/A_Bosch_1.jpg
I done a rapid set up and shot a hi-def close up, with a Nikon D-750 . . .24meg . . .babycakes !
That potential overkill lets me downgrade in density and definition later on .
I used my own, one off a kind, custom made wire frame "tripod" that mounts to the front of the camera and extends out 4 tempered wires to meet at the 4 corners of a square wire frame.That end frame just rests on the opened page of a book / magazine and the weight of the frame will hold the page perfectly flattened and at a precise distance. An opaque ring flash then provides perfect, non reflective lighting.
MICAMOLD caps . . . . .
I have seen MICAMOLD caps in those past 83 years in almost every type possible.
If one was molded into a .postage stamp profiled case using 6 dot color code layouts, and if the first dot was black, figure upon your having found a silver mica unit. If a silver dot, expect a paper cap in sheep's clothing.
Also I have seen electrolytics and metal bathtub cases with mounting ground tabs and multi sections.
Your provided info of dual 0.05 ufd units, is being a dual unit with one section providing AVC buss filtering and cathode bypassing of an IF amplifier stage.
Since you no give pics . . .we bring pics to you:
See which one is your unit(s) and report back, and we will fill you in.
https://www.google.co.in/search?tbm=isch&slpassthru=1&q=" Micamold " Capacitors
THE SCHEMATIC . . . . .
73's de Edd
