Ok, this is a long one. Antiques are my side hobby. A buddy recently gave me this amp that causes my hobby ven diagram to have overlapping areas.
It is clearly old. It had obviously spent some time outside. It had leaves and sand in it but still pumps alot of noise. I need help figuring out its proper usage and fixing the issues, if yall wouldn't mind. I know I should hit up a musical forum for this, but I trust yall more and I wanna run it by you 1st.
AudioGuru, I know you got this.
1st, is this a regular amp? Or is this just an equalizer and I need to plug an amp into it? Notice it has regular and -10db inputs on the front, "power amp input" and "pre-amp output" on the back. I can plug my phone or PC sound output into either of those back ports and I get great sound, just the volume knobs and equalizer on the front does not affect it.
When I plug into the front, I have volume and equilizer control. That "BRT" button on the front doesn't seem to do anything. Plugging straight into the front without power amp yields low quality sound and low volume. Plugging into the back via "pre amp output" or "power amp input" yields great sound and volume. It seems odd to me that pre amp output works as an input...
Anyways here's the issue the amp has: After about 15-30 minutes of music (using front or back as input), the sound slowly turns into static until all you hear is static. I feel like that huge monster cap (7800 uF, 100VDC) is bad since it slowly dies out. Then when I can no longer hear music, I turn off the amp and for a few seconds until power runs out, the sound quality is loud and good again, then the amp powers off.
So how can I fix this badboy? Not sure I have that same monster cap, but I'll buy one if need be. This is a killer amp. Enclosed, you will find tons of pictures and a youtube vid showing various angles incase you need it. If you need more angles, lemme know. Yalls help keeps me looking like a god to the yokels around my neighborhood!
Thanks!
![20200221_075723.jpg 20200221_075723.jpg](https://makerv2.webteractive.co/forums/data/attachments/45/45600-efda06743b0224ca3824638cf8e3b9c2.jpg)
![20200221_075451.jpg 20200221_075451.jpg](https://makerv2.webteractive.co/forums/data/attachments/45/45602-6c7eb035928519c895dfb97cf10d3704.jpg)
![20200212_201308.jpg 20200212_201308.jpg](https://makerv2.webteractive.co/forums/data/attachments/45/45598-54e4be40a5b42bd7352673fb2427f478.jpg)
Thanks!
![20200221_075202.jpg 20200221_075202.jpg](https://makerv2.webteractive.co/forums/data/attachments/45/45599-683279faaaa1b9ed49b44879f5c8a7f7.jpg)
![20200221_075523.jpg 20200221_075523.jpg](https://makerv2.webteractive.co/forums/data/attachments/45/45601-847ca7ebb4cad8ffe7b5338e5c41a33c.jpg)
