Hello All,
For a number of years I have had a speed camera detector device in the draw, I used in a car 15years ago.
I tried it on a motorbike back then but it triggered all the warning lights every 10 -20 seconds as I was travelling on the road. I contacted the company but they had no idea why, so it ended up in the draw for years.
I am planning a trip to Scotland on a motorbike (which has a 12 volt and USB sockets fitted) this summer and decided to try the old detector again. The exact same thing happened again in the 12 volt socket, but in the 5volt USB it was fine? But travelling a long distance plugged into the micro usb socket on the device is not good for the connection as it vibrates on the windscreen , so I would prefer to connect it to the 12v Robust sockets.
My theory is ... as the 12v socket on the bike is wired directly to the battery, as I twist the throttle the magneto is pushing amps into the battery and also to the device which triggers all the warning lights to activate (the same as switching the device on).
So to my question ... is there a component resistor, diode, that I can fit from the battery to the 12v socket that would deliver a constant current to the socket as a stand alone battery would?
Any Suggestions would be appreciated.
Thanks Bob H.
Thanks Bob H.
