Nemo
I got a "static dissipative" mat and measured its resistance between two
points. On the underside, which is black, it's just kilohms. But on the
top surface it's too high to measure - I checked the DVM with a 50Mohm
resistor and it measured 51M, so I trust the DVM. I asked the
manufacturer how this insulating surface is meant to prevent static
building up and damaging components... tellingly, no answer was
forthcoming, "we'll, uh, get back to you".
I reckon it is possible that these mats work on the principle that
static flows over surfaces, so it leaks round the edges to the
conductive layer below. I can quite imagine this being worked out by
some genius in the 1920s and no one remembers why it works any more:
"we've always made them that way"; there seems to be an increasing
number of technologies where the fundamental knowledge is lost. But
here, the top surface does really seem to be basically a plastic
insulator. I don't have an electrometer or other handy device to see if
it holds charge, can anyone reassure me these mats really do work? Or a
test to prove they do not, like levitating paper after rubbing the mat
to build up a charge?
TIA
TIA
