L
Lydokane
I want to make a belt buckle with two red LED lights (non-flashing).
I am hoping to power it with one or two watch type batteries or coin
cells. I know very little about this type of electronics but I have
been doing some research in this newsgroup and on the Internet as
well. Could some of you wise, all knowing, electronic gurus point me
in the right direction for what type of materials I'll need?
I think I have found the belt buckle that will work. I want to get a
skull belt buckle, drill the eyes out and insert the red LEDs. I have
seen some of the promotional pins & buttons that the bartenders wear
to promote a new beer or liquor. This is the principal that I would
like to base my buckle on. I might want to go a little brighter
though (if possible).
So far, I figure what I'll need is:
2 red LEDs (duh!)
Power (watch batteries) + battery holder(s)
Resistor(s) – how much resistance will I need?
PC board? Will I need this or can I just run small wires from power
cells to resistor to LEDs?
Switch of some type
For the LEDs, I went to allelectronics.com and found this:
CAT# LED-21 or this CAT# MLED-1
Would either of these be suitable? If so, how much resistance will I
need?
For the batteries I found:
CAT# LBAT-33 or this CAT# LBAT-20
I think I'll have to go with something smaller (physical size)
because…
The holder seems to be a toughie. I haven't seen much that would be
small enough to fit in the recess of the buckle.
So this is what I have figured so far. Am I close? Could somebody
fill in the blanks and/or make any suggestions?
Thanks,
PR
2 red LEDs (duh!)
Switch of some type
need?
because…
Thanks,
PR
