Another HD44780 question
_
Using a 4-bit interface, I assume I should tie D0-D3 to ground. I have
decided to enable the R/W line, and might be reading from the LCD. Should
I put a resistor between D0-D3 and ground, or can they be directly
connected?
Jan Panteltje
connected?
It says leave D<3-0> NOT connected.
James Beck
My Optrex manual says to ground the lower nibble to use in 4 bit mode,
but I have seen others that say to just N/C them.
Jim
Joel Koltner
All the ones I've used had the unused bits unconnected.
I suppose the Optrex manual is trying to save a little current, perhaps, that
might be drawn if the inputs float up to mid-Vcc or thereabouts?
If you look at their initialization protocol it's clear that the actual values
the parts sees on those pins are all "don't cares."
Jan Panteltje
If I measure on those unused data lines I measure 4.98V.
Possibly there is some internal pullup.
James Beck
I'm not sure. Would it make a difference on a display that says the
values are don't cares if they are grounded? I've never tried it.
John Devereux
If it got into "byte" mode, then you tried to read out a location with
"ones" in it, the displays drivers would be running into a short
circuit. So floating seems safest. Or pull-down resistors of course.
James Beck
I can see that as a possibility. I grabbed my Optrex "DOT MATRIX
CHARACTER LCD MODULE USER'S MANUAL" (the caps are theirs) again, just to
be sure, and it does say to 'ground' D0-D3 if using 4 bit mode. Maybe
they have some series resistance on the lines? Maybe they hope the CMOS
drivers hold up during a fault condition? Maybe it helps sell more
displays. :)
Jim
Spehro Pefhany
Better to use pull-ups, if deemed necessary. Pull-downs would waste
current & could put the inputs into indeterminate states. There are
internal pullups (10-120uA on the HD44780U DB0–DB7, RS, R/W inputs)
according to the datasheet, presumably the older chips and clones have
them as well.
Best regards,
Spehro Pefhany
Anthony Fremont
have decided to enable the R/W line, and might be reading from the
LCD. Should I put a resistor between D0-D3 and ground, or can they
be directly connected?
I've always left them unconnected in my tinkerings. IIRC, the HD44780 has
internal pull-ups on the data lines.
_
them as well.
Best regards,
Spehro Pefhany
OK, I just didn't think it would be good to have them wobbling around.
Internal pull-ups so if not connected they are still predictable works for
me.
Tom2000
connected?
I leave them open.
Tom
