The code makes an exception to safety grounding switch based
upon no exposed conductive parts. I don't have the copy.
However I verified it because so many electricians are not
grounding the switch AND passing inspections. Checked out the
2002 code book. As I had posted previously:
If the container is plastic, then a safety ground
requirement to switch is not required. HOWEVER - those screws
are metal. They can become exposed hot parts. How do they
get around that problem? I don't know.
It is stated in code book. When the switch and its box are
not metallic, then code says safety ground is not required.
And yes, those exposed metal screws, for some reason, are not
considered conductive. Had the same questions and doubts.
Looked it up. Inspectors were approving just as code stated.
