I'm working on a variable bench power supply design. It has variable
voltage out and variable current limit. Right now the current limit is
implemented with an op-amp circuit. The voltage and current set point
is being supplied by two DAC (MCP4922) outputs, controlled by a dsPIC.
I starting thinking: the dsPIC is already monitoring current draw via
its A/D and an instrumentation amp, why not do current limiting in
software? Essentially I check the current draw of the load against the
set point, and vary the output voltage accordingly using a PID
algorithm. The dsPIC A/D is 100K samples/sec.
I have a gut feeling that this method will be vastly inferior to the
traditional analog limiting. Anyone have experience with this?
