Hey guys, I'm in a bit of a pickle here with this amplifier circuit. I've a few TDA 2009 chips on hand, hence my choice to use these.
I've basically built the reference schematics listed in the datasheet. I have two of these chips on a single board, one in a stereo setup, and the other in bridged mode. The sound source is the line level out of a PC, which, on the pcb, gets to the stereo amp, and gets a mono mix through some resistors into the bridged amp which goes to a subwoofer. It is powered from the PC powersupply's 12V rail.
The setup does work to some degree, but something's not quite right. I'm getting an odd white-noise, and all sorts of HDD and fan-noises in the signal, along with severe distortion even at low volume levels. The amp chips also get quite hot, something I wouldn't have expected from these guys, seeing how they're fairly low power. Pretty sure these symptoms will be somehow connected.
I already built a simple stereo amp with these chips, which did work well, but also suffered from HDD/Fan noise, it didn't heat up near as much though, and didn't have any distortion.
Does anyone have any tips what the culprit could be ?
I'll post my schematics in a bit (soon as I get to my workshop puter)
Thanks in advance!
Thanks in advance!
