Ampli High Current High Voltage Large Bandwith
brunocat
We are involved in one project which needs to amplify a sinusoidal
signal (~15 MHZ) without harmonic distortion (at least minimal
distortion) and we are looking for an Amplifier or a components
assembly with the following features:
output current >= ~ 1.5 A
output voltage >= +/- ~20 V
bandwidth >= 30 MHz
Until now we have used the LT1210 component but the voltage is not as
high as necessary at ~15 MHz.
Is there some one who can help us on this subject?
Thanks in advance,
Bruno.
Rich Grise
bandwidth >= 30 MHz
Thanks in advance,
Are you looking for this sort of thing?
http://www.google.com/search?q=broadband+rf+power+amplifier
Good Luck!
Rich
brunocat
Thanks for your answer!
Actually, we are looking for a discrete component or an assembly of
discrete components with all these features:
bandwidth >= 30 MHz
low distortion
Thanks again,
Bruno
brunocat
bandwidth >= 30 MHz
low distortion
Thanks again,
Bruno
K
Ken Smith
bandwidth >= 30 MHz
Can the output be capacitively coupled? This would make things a bit
easier.
What output impedance do you want?
brunocat
The output can't be capacitively coupled,
and the output impedance must be under 10ohm.
Bruno
John Popelish
Bruno
Down to what frequency?
W
Winfield Hill
brunocat (Bruno) wrote...
Can it be a bridge output (two push-pull outputs)?
Your +/-20V spec is a killer, and would be a much
more managable +/-10V with a bridge output.
What are you trying to make?
