D from BC
I made an audio amp that's powered off my PC's 12V.
Everything is fine except for some digital noise.
I can hear digital noises when I scroll, move the mouse and when drives
are spinning up('rrrrrrrrrrrrrrrrrrrrrrrrrrrrr').
I suspect it's a ground problem only fixable by some form of isolation
between signal ground(analog from sound card) and power ground from the
switching supply.
If the noise were 1/2 as loud, it would be good enough.
Should I try to find an optical S/PDIF receiver and a codec to fix the
ground problem?
My PC has a S/PDIF optical out.
switching supply.
ground problem?
