Okay so I have worked up to this point with yall's help and this is the closest I've ever come to completing a project LOL. I've been working on this for quite some time. For me this is a rather large project. I'm taking an amp but instead of speakers giving LEDs to light. I want to make two of them for an electric guitar and violin so that any sound they produce will cause this led to light. So easy a caveman could do it right? 2 f***in months later..... Here I am.... Anyways here's the setup I'm using. I will either splice into the existing or add a little Piezo pickup. Those both work. And they will lead to this TDA7231A amp:
![Screenshot_20191210-151426.png Screenshot_20191210-151426.png](https://makerv2.webteractive.co/forums/data/attachments/45/45466-93cb34069cf660007690502ac7d6a72a.jpg)
And just instead of speakers I put one LED. I should also let you guys know that one of those capacitors seems to be without polarity. I did not have that value so I created one bye connecting two capacitors of double the value in series. I was told that this would create a capacitor of half the value of the two combined but with no poles. It's the best amp I've ever built anyways, with the most gain and least noise. This works great for one or two notes. Then it just seems like there's a capacitor that giving this LED power and it starts out strong but slowly Fades. Then if you leave it alone for a long time and give it a chance to charge, it works again. It takes a long long time to charge. I've even tried connecting the speaker output as the triggering current for a transistor that should allow a good 3 or 4 volts to flow no. But it doesn't it behaves the same way. I'm pretty sure I'm connecting the transistor correctly, maybe not. Here's what it looks like fully connected with a transistor that seems to do nothing but working, if for only the first few notes:
![20200128_155802.jpg 20200128_155802.jpg](https://makerv2.webteractive.co/forums/data/attachments/45/45467-6e53824d9317dc34c84ac7130b71e946.jpg)
I thought about using a relay instead but I don't have any with an activation voltage low enough. It would be nice if it was a dim light for quiet noises and a bright light for loud noises oh, but I would settle for just light at 1 brightness for any sound. I just can't get this for more than a few notes and then it needs to recharge. What can you guys suggest? Perhaps changing one of the capacitors? I've fiddled with this so long it would be a shame not to get it working. I appreciate y'all's help.
Edit: oh and I did try adding another amplifier between the LED and the first amplifier. Oddly, the same thing happens. There is no amplification. The LED works for the first few notes then quits. I don't get this, amps amplify.
Quote
Report Attach files
Share:
FacebookTwitterWhatsAppEmailElectronic Projects Design/Ideas/Reviews
Copyright © 2019 WTWH Media, LLC. All Rights Reserved.
Quote
Quote
Report Attach files
Share:
Quote
