Ok first things first, I hope I dont garble on and run on and on about useless stuff because Id hate to make you all mis-understand me more than I probably will.
Picked this car audio amplifier up for $10.00 yesterday. The boy said it had been sitting under his bed for a couple years after it went into protect mode, So I addressed it myself hooked only the power 12V+, Remote, Ground up. Red LED shines on and throws a *protect*. Next thing I do is open up the bottom to let me into the internal and expose the PCB. right off the bat, I dont see anything wrong. no raised caps, no darkened spots or anything.
So then I break it down to where I can address the POWER side and the OUTPUT side of the amp.
I know how to check a transistor with my volt meter. All of them read the exact same reading.. And showed the same across the board which lead me to believe since they were all showing the same resistance they were in-fact good.
POWER SIDE
OUTPUT SIDE
However, When I got to these 4 components
two are FMG33R and two are FMG33S
as they look like transistors when I put the leads on them it automatically goes to an Open circuit. will not read an ohm load which in turn to me, means dead short.
but they don't -look- like typical transistors which is why I was wondering if I was diagnosing these right and checking them right. As if I am Im pretty sure I found the culprit as to why this amp is not working. And found the replacement parts on ebay for a mere 2.00 apiece. (not a bad little investment for an amp that retails new for 1000 dollars on ebay)
anyways, I appreciate any help as you all can give me, and wanted to make sure I was steering in the right direction to fixing this beast.. as Im sure it will knock the hell out of a set of subwoofers lol.
![406099011.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099011.jpg&hash=ae87c19e310446d70406dc285185e433)
![406099038.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099038.jpg&hash=bfa3c5ff472f1e1a45404d6b4ba5b870)
POWER SIDE
![406099049.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099049.jpg&hash=74d9f8b64cb7cca985716ab59eb693e5)
![406099058.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099058.jpg&hash=bb4548f5180f7c975b0af5fd7b5be954)
OUTPUT SIDE
![406099085.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099085.jpg&hash=b3d1060eaf2b9c5d03cc64c6ad4614b7)
![406099116.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099116.jpg&hash=df836a7398f0e549ef1ad6854f82078a)
![406099250.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099250.jpg&hash=f4ebf525c37efdbaf0d296e56a527373)
![406099205.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099205.jpg&hash=f154f60eac9c94ce9992a7b196c4d687)
![406099126.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099126.jpg&hash=256fa8f66331124d0c44fd3159f5d410)
![406099140.jpg](/forums/proxy.php?image=http%3A%2F%2Fpic100.picturetrail.com%2FVOL717%2F2737902%2F24326664%2F406099140.jpg&hash=fa2ad5795bdabf7125731315c00315a7)
