sorry a bit language issue has arisen.. i think.. sorry harald bro..
actually here is excessive blackouts.. 1 hour blackout after every 3 hours is normal..so it was just to go blackout that i couldnt properly omprehend his reply.. and to explain more i typed a whole paragraph but light went .. so i just posted the short reply from my mobile..
my issue is already solved.. here is solution
http://sv1bsx.50webs.com/charger/charger.html
...reason i wanted to do charging this way is that i have intellignt charger but issue is ...
the charger expects cells of aa or aaa sizes.. and each cell is individually cgarged..
plus the battery pack that i have is tab soldered and is in pack.. it wast used for few momnths and the voltage of entire pack were .1 volts instead of 4.8volts.. so wnted to trickle it with small current to bring the pack voltage to sufficient level.. then hope the device in which the pack will be installed accepts it and charge it from their nwards ..
its on charging .. and charging at 80mA of current let me se if it brings the cells to life..
once agaimn a heartly sorry for being blatent ..but language issue arose.. i thought the of course was part of ur immediuate next statement..
