AM (DSB) ring modulator
Hello all,
I need help designing a ring modulator for AM(DSB) instead of DSB-SC..
  • RM.pdf
Welcome to out forum.
Your request looks like homework to me, so I moved it to the appropriate forum.
As far as I know the idea of using a ringmodulator is to suppress the carrier, therefore you can't use a ringmodulator to generate plain AM unless you add the suppressed carrier after the ringmodulator, which would be paradox.
Can you explain your goal a bit more detailed?
