The extrusion shown appears to be fabricated from square tube and plate.
If not readily available as shown, is it possible to fabricate it from the two?
M.
Since I have a fair stash of aluminum flats and square tubing that was my original plan. But then I've been so spoiled by China's Ebay cheap prices I thought why go through the work if I can get it in a single extrusion. Problem is I didn't see any on Ebay and the stuff that is available are U.S. suppliers with shipping costs that are absurd. If I was equipped with aluminum welding outfit I'd be welding it. Since I don't that leaves screws or rivet joining.
One of these days I'm going to break down and by a cheap Horror Freight wire welder.
I Googled "flanged square extruded aluminum tubing" and came up wit all kinds of stuff, including this link to
Coltwell Industries, which seems to make something like what you're looking for.
That's exactly what I'm looking for but I suspect that link is a wholesaler that doesn't deal with short cutoffs. I need only 16 inches.
Hey Chris, do you have any aluminum wholesaler's in your area? Think of places that sell to gutter, fascia and soffit tradesmen and you should be able to source that.
It appears that Bluejets below agrees.
I had an aluminium screen door frame built from this exact same profile.
(aprox. 2mm wall thickness.)
Made to fit inside an existing exterior door steel frame as used in concrete block walls.
Heck, I live in the land of screen rooms. In fact all my posts and computer time is done from my screen room. When Wilma blew through here the small screen room I had in the front of the house was damaged. I dismantled it and stored the stock in the back hard. It's now buried under years of leaves but I'll look for the door frame stock.
Thanks everyone,
Chris
