John Crighton
Hello All,
How common are Aluminium bobbins for 50/60 Hz
chokes and inductors? This is the first one I have seen.
I was at a ham radio field day recently and picked
up a heavy duty coil which I thought might make
a good choke for small home made rectifier unit
for a small welder. I will add the iron core when I
find some laminations.
The winding is aluminium strip 0.7 inches by 0.1inches.
There are two strips of aluminium making up the 0.1 inch
thickness. The strips are covered with some sort of
fabric tape hand wound over the two strips.
The whole winding is taped and painted so I can't see
how many turns.
The hole in the bobbin measures just over 4 inches by 1 inch.
The bobbin is 3.3 inches wide.
I didn't notice, since the whole coil assembly is covered
in thick grey paint, but the bobbin is made of aluminium.
I just assumed the bobbin would have been made of
some sort of insulating material such as fibre glass or
paxolin. An aluminium bobbin was a surprise to me.
Is this a common practice to make heavy duty robust
bobbins for low voltage applications out of Aluminium?
Regards,
John Crighton
Sydney
how many turns.
Regards,
John Crighton
Sydney
