"Lee"
Also, Wiki says: "A TRIAC which can only operate in quadrants I through
III, and cannot be triggered in quadrant IV, has improved turn-off
(commutation) characteristics.
These devices are made specifically for improved commutation when
controlling a highly-inductive load, such as a motor or solenoid, an
application where normal TRIACs have problems due to high voltage/current
angles"
** The wiki quote is a bit misleading - cos there are two specs for dV/dt.
1. The regular spec referring to the "withstanding" condition where the
triac is in the off state.
2. The other called " Commutating dV/dt" - referring to the condition where
the triac has just stopped conduction because the load current has fallen
below the holding threshold, about 15mA to 50mA for most devices. At this
critical point in time, the device will retrigger if the voltage rises too
fast. The back emf from an inductor can easily do so.
The commutating figure is generally much lower that the regular one, up to
100 times lower - eg the triac ( or SBS ) used in the MOC series of
opto-couplers has a regular dV/dt of 10V/uS, falling to a mere 0.1V/uS while
commutating off.
A simple RC snubber across the main triac normally solves the problem.
BTW: If properly designed, the triac/SBS in a MOC goes off as soon as the
driven triac begins to conduct so the commutating dV/dt issue never arises.
.... Phil
