Hello All!
I'm needing a little help. I'm trying to design a circuit that, when switched, trips a gfci receptacle. The basic concept is to have the circuit built with a plug in that will be plugged into the gfci receptacle in question.
Here's what I know: I understand that the circuit will be connected to the hot wire and ground. Between these two points will be the switch and one or more resistors. The resistors create an imbalance that the gfci detects and reacts to.
What I don't know: What resistors are needed to get the desired results.
Thanks in advance! You guys are great.
mperedithe
mperedithe
