Hello! I am building a circuit around the IC with part number ncl30105. It is a current-mode controller for driving LEDs. It uses current sensing and a constant OFF time to control the switching of an external mosfet. The OFF time is set by using an external resistor, so you can set the off time based on your specific needs. The current limit can also be set in the same way for whatever current your LEDs require.
I really like this device because it makes controlling the current to my LEDs relatively simple. If I want to dim the LEDs, there is also an enable pin that allows an outside PWM signal to turn the driver on and off independant from the constant current control.
The problem is that I can only find one seller of this chip and the price isn't all that great. If I could find an equivalent chip that basically does the same thing, I would love to hear about it. Anyone know of such a chip??
If it came down to it, I could always program a microcontroller to do the same function.. but that's a lot more complicated and not all that cheap either.
I've attached the datasheet for this chip.
Thanks for reading!
Thanks for reading!
