Alternative for Meanwell constant current supplies
Joerg
Folks,
Need constant current supplies around 3A, voltage range to be tolerated
should be 16V-21V or wider, outdoors, weatherproof, UL. The Meanwell
HSG-70-24 is a few volts higher than we need but would have worked nicely:
http://www.meanwell.com/search/HSG-70/HSG-70-spec.pdf
The problem with them is sluggish to no responses from the factory and 7
week lead time mentioned at the few distributors there are. That's no
good because we need several hundred by latest end of April.
Does anyone know other sources? Probably from the direct LED drive
market. Should not be much over $50 in 1k qties.
Joerg
Joerg said:
Folks,
Guys, nevermind, miraculously I found a source that has much bigger ones
in stock:
http://www.trcelectronics.com/Meanwell/power-supply-hlg-h.shtml#150w
We'll just use oversized units for a while.
