Sir Crippy . . . .
Reference to:
https://www.electronicspoint.com/fo...i-need-to-hook-up-9-pinmini-din-wires.275693/
Now, if you " apprehended " and properly " congested " all of my info contained within that posting, all was being correct.
As I mentioned, the small sizing of the D mini connector drawing , gave me a "rat's anal orfice" . . . . "chance in Hades" of my being able to place legible
SIZE numerical markings
WITHIN that connectors confined drawing, therefore I opted to use, easily fitting, color coded squares within the connectors, being placed adjunct to each relevant pin.
As I said, textually, within the post, the external numbers were then being cross referenced to the proper EIA color codes.(In case of a lack of knowledge of EIA color codes. )
This had
NOTHING being related to the wire colors, going to and associated with the DIN connector pins.
The gray marked flowing box charts at the far right give the:
1. AMP function connection . . .as . . .
2. Related . . . to its wire color . . .as
3. Related . . . to its DIN pin connection.
That one . . .enhanced and reworked photo I used . . . . was the sole GOOD referencing being available, as all of the rest were being BLURRRRR city.
73's de Edd . . . . .
Why in the world, do they put Braille dots on the keypad of the DRIVE -UP ATM ?
