The Altec Lansing 221 is a 2.1 (two satellite and one woofer) speaker system. It is one of the best sounding low power speakers I have heard. However it has way to much bass. Most Altec Lansing speaker systems have a bass level adjustment on the sub-woofer. I am going to try either installing one or soldering some 10W resisters in series to the line going to the woofer driver.
They are using the TA8229K:
http://audiolabga.com/pdf/TA8229K.pdf
And the BA5417:
http://rohmfs.rohm.com/en/products/databook/datasheet/ic/audio_video/audio_amplifier/ba5406-e.pdf
It appears to me that the BA5417 is used for the woofer. And they are using a large electrolytic cap to eat up the highs. (purple '>' in pictures)
the through-hole image is flipped.
I'm thinking that it might be best to go with the potentiometer because adding resistance to the crossover may change the crossover frequency. However if it is before the amp it should be fine. (famous last words)
This is quite an ambitious project for me. I'm not sure how to implement a potentiometer right now. I'm beet. Does it sound like I know what I'm doing? Any Ideas or words of encouragement/discouragement? You are wonderful thanks for reading!
And the BA5417:
