Alarmnet 7835C - using main control's battery in place of on-boardbattery for backup
Mike Cooper
Question for anybody experienced with AlarmNet transceivers....I'm
planning on adding an AlarmNet 7835C to my existing system and would
prefer to have the battery backup of the main panel supply the 7835C
instead of the 0.7 amp-hour battery that comes with the 7835C, which is
harder to locate an identical replacement for.
So, if I were to answer no to programming question 33 (Battery present?
Y/N), what exactly does this disable - the 7835C's on-board charger,
low-battery monitoring, or both? Or would it also disconnect the
battery terminals altogether so that the unit would not accept any DC
current from those terminals during an AC outage? Knowing if the
charger still functions even with a no to Question 33, I assume, would
dictate whether I need to wire a diode into the positive lead between
the 7835C battery positive post and the Vista control's battery positive
lead. Your thoughts?
Best regards,
Mike
A.J.
Don't not use the 7835C, get the 7845c instead. Either case, it is a good
idea to have a battery in the unit just incase there is a break in and the
main control panel is ripped off the wall, the alarmnet will at least report
trouble signal.
Similar threads
Replies
4
Views
1K
Nick Markowitz Jr.
Replies
1
Views
951
Devin
