Dac said:
Anyone seen this before? The inside fan is ok, but I am guessing the
outside fan is stopping and drawing massive current. Dont have a current
meter and cant get to the outside fan either :-(
Yes. It is normally associated with too small a breaker current for the
start current of the compressor.
Check the specs in the installation instructions / user manual and compare
these to the rating of the breaker installed.
Quite often sparkies who want to skimp on using the correct gauge cable for
the load current / distance fit a smaller breaker to prevent the house
catching on fire in the event of a fault / too high a stall or start up
current in the compressor motor.
The indoor unit is most likely running on a separate circuit or breaker.
Get it fixed if it has been recently installed or under warranty - should
cost nothing to fix a stuff up.
If out of warranty get a qualified a/c sparkie to check it out.
Cheers,
Alan
