Brent Geery
OK, it looks like most methods of collecting rain water will be very
expensive in an arid location, not to mention the need to store lots
of water. So, even a $15,000 deep-well, and treatment of the brackish
water, will probably be more practical.
Gigawatt mentioned looking into air wells and dew ponds as a possible
alternative. I didn't find many useful links, but here they are
anyway.
http://www.rexresearch.com/airwells/airwells.htm
http://www.bagelhole.org/article.php/Water/350/
http://www.opur.u-bordeaux.fr/index.htm
The theory for both is to cool down the collector surface below
dew-point of the air, and condense the moisture out. Most of the
devices use the chilling effect cold space during a clear night to do
the cooling. Dew ponds insulate themselves from the earth via
insulation, and most air wells depend on mass to hold the cool.
However, at least Courneya's air well uses the earth itself as the
heat sink, instead of nighttime radiation into space.
Courneya's design seems the simplest and cheapest to construct, but
I'm confused if the device will work at all, and how much water can be
expected. My main source of concern is that the ground, even many
meters down, can still be as hot as 75 degrees F. I don't think Hot
(100-120 degree F) low humidity air (10-20%) will give up any moisture
at such a high ground temp.
Dew ponds also look relatively simple to construct, and using
radiation into space, they can get much colder than Courneya's air
well design that depends on earth heat-sink. But, I still have a
question on how cold the dew pond cold get, how long it would stay
cool, and how much dew would be collected for a particular size pond.
Anyone have a clue about the possibilities of air wells and dew ponds
under these conditions. I'm way out of my league.
anyway.
