I picked up a Classic Sport Air Hockey table and the scoreboard isn't working. When I first got it the E & D segments were not working nor the speaker. I replaced the speaker with on from another unit and trying to figure out the segments from an old thread from another site, I replaced the transistors for those 2 segments. Now all the segments seem to light up some what dimly and the E, D G segments seems to always stay lit, but not full on bright. I noticed 1 or 2 other transistors getting really hot until I unplug the speaker. I couldn't read anything on the old speaker and I had an 8ohm 2 watt speaker from another electrical item so I tried that and that is causing the other transistor(s) to get hot. Also the countdown is fast, it actually takes about 6 seconds to count down 10 seconds on the display. After about 1-2 minutes, the G segment starts to flicker a bit, but it is definitely hard to read the scores. Any help would be greatly appreciated. I tried removing those 2 transistors again and then the whole board got wacky, only the right zero would light up for both home and visitor.
You can see when 10 minutes is selected, you can't read 10 minutes, when 20 is selected, that reads ok, and when 30 is selected, again, you can't read it. The one picture has the timer running and I scored one puck on the home side and you can see it doesn't show a 1.
Thanks,
Karl
Thanks,
Karl
