It looks like your at the panel of the LCD. Brightness is controlled by the A/D board and inverter. I don't know what voltage your using.
First I would determine if you inverter is working properly. You can run the inverter without anything else attached except the lamps. First determine your voltage required. Some units are set up kinda strange when it comes to the main power in and switched voltage.
Lets say you have a 12vdc input, and a 5vdc switched voltage. You could run this off 1 12vdc power supply and use a resistor to drop down for the switched voltage. This is just a example, you will need to get the correct readings with your meter. Brightness is sent from the A/D board to your inverter. The panel just processes the video.
