AGC IC required
Status
Not open for further replies.
I want to control the frequency output from 1Hz to 10Mhz . The higher frequencies (above 100KHz) show attenuation. So, i want to use AGC ic to make all the outputs constant.
I browsed for 2 days and found many ICs like CLC 430,520, but they do not suit my frequency requirement.
I finally got IC THS7001. But the gain adjustment is a kind of manual instead of automatic. We have to manually set the control inputs depending upon the frequency. I want this process to be automatic. Also, there are lot of factors to be checked while building eval board of this IC.
I want an IC which has AGC which is AUTOMATIC gain control.
Please don't post multiple threads for one problem.
Your attenuation problem is caused by your basic lack of understanding of what capacitors do.
Status
