Mark Harriss
I scored two NEC projectors today for $25, these are a
Multisync MT830+ and a Multisync MT1030+. They were sold
as having a faulty power supply that would only run in
standby mode, but turned out to be the air filter switch
which stops the unit from running if the filter is missing.
Anyway after playing around with them for a bit, each had
a display fault: the 1030+ has shadowing of text before the
actual text and the 830+ has a magenta shadow before the
actual image, this shadow is a few pixels horizontally
before the image and is in perfect alignment. Changing the
display setting to be upside down doesn't change the
shadow position, i.e. it doesn't rotate with the image.
Has anyone experienced a similar fault with a LCD projector?.
I was hoping the alignment could be adjusted somehow, possibly
in software.
tia
Mark Harriss
in software.
tia
Mark Harriss
